Bayou Bert's RV9A Web Site
Date:  3-20-2014
Number of Hours:  5.00
Brief Description:  Panel Organization
Time to get organized and rolling on panel.
First pic is all the electronic boxes that need to be mounted behind the
panel. Below yard stick is inside behind panel. Above is mounted
in the engine area and firewall.
Second pic shows the left side mounting area that will be under one
of the access door. I built the alum partition so I could mount boxes
on both sides.
Panel is at the painters having a dark gray color put on it with a no glare
clear coat.
All the Boxes.
All the Boxes.
Left Inside Mounting Area
